Ok selling a few thinks as I am about to sell my car and dont need them any more
- R33 gtr wheels with tyres painted in dark bronze $1,000
- R32 gtr seats in good condtion $600
- R33 gtst pedders coilovers in good condtion and not leaking $850
- Honda accord euro wheels 5 stud $100
- R33 alternator $50
- R33 5 bolt drive shaft $50
Located in Wollongong (1hr south of sydney)
PM me or call me on 0424255931
https://www.sau.com.au/forums/topic/380892-r33-parts/
some more stuff for sale as well
- r33 cluster with working tacho, 95,000km on it $100
- R34 stock caster rods with bushes not leaking $50 pair
- R33 boot lid with spoiler in gunmetal with brackets and struts $20
- r33 spolier brake light $20
- R33 side indicaters 2 sets $20 each set
https://www.sau.com.au/forums/topic/380892-r33-parts/#findComment-6083581
thanks mate, yea the do look good, 2 wheels have 215/45R17 bridestone re050a about 50% left, 1 wheel has 235/45R17 dunlop sportmaxx about 30% left, and the wheel has a 235/45R17 goodyear excellence about 30% left
So I hope this helps anyone out
https://www.sau.com.au/forums/topic/380892-r33-parts/#findComment-6092890
https://www.sau.com.au/forums/topic/380892-r33-parts/#findComment-6098788
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
