Hey Guys,
I have a set of 17 inch multistud stud rims that I haven't used in quite a while.
They used to belong to my Nissan Pintara (1990 U12) But I sold the car ages over a year ago with all its stock equipment on, and really don't have a use for them any-more since my R32's stock wheels are better.
Two of the rims themselves are fine, 2 others have been slightly bucked by hitting a large pot hole. 2 Of the tires have average tread, two are pretty bad.
They do wobble at very high speeds, but that being said they don't have any fractures, and I drove on them in that condition for over 6 months without issue
Originally I was going to take the rims to be reshaped and get new tires, but I don't really have interest.
Im after $150 for all 4 as is, I paid over $1100 for them about 2 years ago so I think that's a fair price for the condition they are in.
If anyone is interested please message me on here, or through my email direct: [email protected]
https://www.sau.com.au/forums/topic/380956-17inch-multistud-rims/
Yeh mate i'll give you $50 for them, better than scrap. txt 0404 513 631 if you change your mind
Thanks anyway, but I would rather see them turned into scrap.
Hey guys, sorry about the lag in replying.
The rims themselves are multistud, fitting the 4 x 100 and 4 x 113.3 Patterns, I incorrectly labelled them before as 4/5's, these are only 4's.
They are 17 inches wide with low profile tyres.
I am looking for $150 firm for them. I paid well over $1000 for them and I honestly would rather get $20 from a scrap yard then give someone a 'bargain' set of rims for a silly amount like $50.
Edited by playboi14
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
