can someone please let me know if evo 9 brake caliper (front) can be fitted on r33 gtst? what do i need to make it fit? also i can i use the evo 9 rotor?
thanks
Next time try searching "Evo Caliper"; the search function is great.:thumbsup:
http://www.skylinesa...hl__evo+caliper
It's not an easy upgrade once you start looking into it. Read and then decide.
Edited by Daleo
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
