As title states, stock 32 air box for sale. I no longer need this as I'm going to be selling my 32 soon. I only want back what I paid for it $100.
Good for silencing your intake a bit or clearing defects.
Located in Aspley. Pm me for contact details.
https://www.sau.com.au/forums/topic/381647-fs-r32-stock-air-box/
  • 4 months later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
