Hi everybody
Recently bought an r32 to find out the 2nd gear synchro crunches like a mother f#%ker.
So basically after a replacement gearbox for the car as soon as possible, can do a swap plus cash if anyone wants the old gearbox otherwise i will just pay cash.
Only honest people need reply i am after a box with no crunching and whining i have already been jewed.Im located on the central coast so tell me what you have can also pick up from sydney easily.
Thanks for your time cheers seb
https://www.sau.com.au/forums/topic/381688-wtb-rb20-5-speed-gearbox-nsw/
  • 4 weeks later...
In need of a gearbox anywhere within nsw
gday there buddy , how are ya , sure do have 1 rb20det manual gearbox in stock ready to go , in good working order .
let me know if your interested man
i am from sydney , out west , fairfield / liverpool way
open 7 days long hours
let me know asap so we can sort it out for you straight away
thanks anthony
