Hey stagea owners,
Currently chasing the factory boost gauge that the rs four s stagea comes with also after a black dayz front bumper for my rs four s. Looking for a excellent conditon front bar with no damage not to fussed about small stone chips but would like the bar to have not been previously repaired from a accident
bump!
Have sourced the triple gauge cluster.
Still chasing a dayz bar if anyone can help out not too fussed about the colour, but instead if possible id be willing to chuck a bit more cash towards it for the carbon insert if someone would be willing to let go of their bar and insert.
Much appreciated.
Currently now only chasing a DAYZ front bar,
NOT fussed about the colour, and NOT fussed if it doesn't come with the carbon fibre insert.
SHOW ME WHAT YOU GOT GUYS! :thumbsup:
Hi Andrew,
Thanks for your help managed to score myself a cheap kakimoto exhaust for my car, and hopefully that black dayz bar in another day or so. :worship:
  • 4 weeks later...
Hey man thats cool what price am i looking at delivered to 5163 south australia, you've caught my attention
  • 2 months later...
Hi scott,
Thanks for your reply but fortunately i managed to source one on import monster in the same colour as my car which was fantastic. Genuine dayz front bar and all very pleased but not so happy on the ETA for it..
Best regards.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
