After spending the past few days off work due to having my wisdom teeth taken out,I thought it would be a good opportunity to detail the car fully instead of only managing to Do half the job on a Sunday morning, which still at the end of it - feels good but incomplete.
Overall spent a good solid 4 hours or so doing each step by hand ( could have taken much longer but seeming that I had already clay barred the car only a few months ago it didn't need all that much this time over)
From what I can see hardly any swirl marks or deep scratches and the pearl in the paint has so much more depth and gloss since when the 34 was first bought :)
Reason for the post is to see if there could be any areas i can improve on, or to show others results of a good days work :)Note: didn't manage to take photos of before unfortunately.
Process/products used:
Wash/dry: Meguiars next gen shampoo, dried off with Meguiars super-glide chamois
Clay bar: Meguiars quick clay kit > wiped down with 100% cotton cloth or supreme shine microfiber cloth.
Cut/polish: Meguiars ultimate compound > again wiped down with 100% cotton cloth or supreme shine microfiber cloth.
Wax: Meguiars next gen liquid wax ( left to sit for an hour to be sure it set, worked on areas listed below) and wiped down with supreme shine microfiber cloth.
* for door trims and seals - Meguiars dash trim and restorer.
* glass/windows - no smear glass cleaner.
* headlights - Meguiars PlastiX.
* tyres/sidewalls - Meguiars xtreme tyre shine.
post-77400-0-85984300-1320464294_thumb.pngpost-77400-0-84849800-1320464679_thumb.jpgpost-77400-0-52885000-1320464327_thumb.pngpost-77400-0-75802200-1320464349_thumb.pngpost-77400-0-68823500-1320464367_thumb.pngpost-77400-0-76240200-1320464699_thumb.jpgpost-77400-0-98426400-1320464715_thumb.jpg
Edited by Allesandro
https://www.sau.com.au/forums/topic/382131-detailed-34sedan-no-buffer-hand/
tech wax is definitely a great wax :)
by far my favourite off the shelf product.
hope you kept washing in between each stage! very important to wash again after clay barring and polishing the car to make sure the cars perfectly clean for the next stage.
what about wheels/tyres! - i found meguiars hot wheels cleaner to be near useless btw, but most of their products are pretty good.
the next steps you can take are to start cleaning up your door jambs, boot jambs, inside the petrol lid with something like a general purpose cleaner and then giving them a coat of quick wax - something like the meguiars spray waxes or spray detailers would be great there.
and engine bay is another area you could work on.
if you want another step up in your detailing get some paintbrushes from bunnings, something like final inspections GPC, and clean every nook and cranny in your interior - especially air vents and around the gearstick boot etc.
and finally paint correction by machine if you're really keen :)
hope that gives you some ideas, but looks like a job well done!
No I didn't wash between each stage! Never seemed to have crossed my mind =o
I generally do clean the rims with acid cleaner(also meguiars) but ran out a few weeks ago so just brushed off as much as I could :)
I've never thought about the engine bay nor air vents, with the vents Id go over the top with the bristle attachment of the vacuum cleaner lol.Again I've never used buffers or machines. A bit of an eerie thought for me since I wouldn't have that technique on using them properly :)
Next time I'll definitely work on the engine bay and inside of the petrol lid, cheers Johnno.Have you booked in to get your wisdoms taken out yet? It's been since Wednesday and my face is still swollen chubby haha.
Oh I forgot to ask have you fixed that door/skirt issue?
as long as your vents arent too dirty its fine, i get a bit anal and get some water or GPC and a paintbrush and brush around there ..
brushes are also good for getting areas like badges on the outside clean
if you get a DA polisher like the meguiars ones their really safe - but hard to do much paint correction
Random Orbitals are good stuff, especially ones with forced rotation - not really too hard but doesnt look like your paint needs it :)
the door has been fixed! greg at spoiler shop loosened the hinges, jacked the door up, and then tightened it up again and it seems to have fixed the problem, but the skirts are still paintless, need to get em off and repainted - $300 :(
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
