im looking at the motec m600 which can be brought for around $3200 and the additional features (launch control, anti-lag etc) for a extra $550. I want to piggy back it to my standard ecu. Are there any other extras needed? Also comparing to the haltech piggy backed, is the installing and up and running costs much different?
I think the FC is the way to go unless your looking to go extreme with the setup. And even then the limiting factor of 4 injector channels will affect the drivability.
When paring 2 injectors on each channel there are 2 methods. One is common and uses cylinders in firing order (1,5, 3,6, 2,4) and requires the ecu be capable having programmable injection sequencing. I have no idea if a motec can do this but considering all the hype about how great they are, i'd say probably. This way you can still run large injectors and have a sane AFR at low engine speeds, and a good idle quality. 1/2 the injectors fire where they would with a fully sequential system, and the other 1/2 are fired 60 crankshaft degrees earlier than they need to be but it still runs because the fuel just sits in the manifold on the back of the intake valve till its drawn into the engine.
The alternate method of wiring paired injectors uses the same pairs as the waste spark ignition, and fires all injectors twice per 720 degree crank rotation. This is batch fire operation, and means unless your running small injectors you cant get a small enough injector pulse width to still get good atomisation of fuel, and have a good AFR at idle. So your idle will suffer with a big injector system.
Parallel wire in's are complicated, but i think really worth while doing if its done right. Especially if your trying to get away with running a fully programmable ecu in a car in a state where aftermarket ecu's are illegal.
I heard about a parallel wire in system on a skyline that would pass all the tests the police could do on it. Unplug the ECU and it wont start.. (aftermarket management gets power from ECCS relay). Unplug MAF sensors causes limp mode... (programmable input from MAF sensors to auxilary on aftermarket ECU triggers a run rich and rev limit function). I am told that police are doing these checks in Victoria on modified vehicles.
A simple parallel wire in would just pinch signals from the temp sensors, throttle sensor, and CAS. In most cases i think the CAS sensor will require a special opto-isolated input interface module of sorts so it doesnt mess with standard ecu operation.
Edited by Vspec R33
im interested in the m600 which has 6 injector drives. Power fc dont cut it as im running no afm and have extensive mods. I further need the connection the the pc and wiring loom. So installing and tunning would be no different to any other piggy back ecu and have similiar cost i assume?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
