Hey guys, i'm looking to get a nistune done this saturday, my R34 use to be NA, at the end of 2009 i did a turbo conversion (put a neo6 turbo motor in with turbo, NOT bolted on)
and basically i am not sure if my fuel pump was changed to the turbo one as i have heard they look identical the NA and GTT fuel pump but have different fuel flow rates?
my concern is that IF i still have the NA one, i would have to change it immediately before i get the nistune done? My car has the basics, pod, return flow front mount, full exhaust and boost t running 12psi. I am guessing it has been changed but wouldn't have a clue, is there anyway to find out if my fuel pump is the NA one or turbo.
Also what are peoples thoughts on getting a nistune done with the standard fuel pump. the turbo in the car is also standard.
any answers to help me out asap would be great thanks
https://www.sau.com.au/forums/topic/382479-r34-gtt-fuel-pump-issuedifference/
yeah fitted the walbro today. was a c*** of a thing to do.. pretty sure it was still the factory NA fuel pump due to the extreme difficulties of taking it out... definatly never been changed. ah well. all good
Lol no, it's a bitch of a job anyway. It gets easier the more you do it ;)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
