r33 mirrors $20ea
r33 front standard sway bar $5
r33 COMPLETE AC LINES AC UNIT HEAT BOX EVERYTHING!! $10
r33 rhf guard $20
r33 drivers glass $10
r33 passengers glass $10
r33 overflow $10
r33 carbon canister $5
r33 dash support bar $10
r33 door locks $5 only passenger side
r33 trim column surrounds $10
r33 left trim sill panel $5
r33 turbo heat shield $5
r33 series 1 idicator in front bar $10
r33 kickpanels $10 both
r33 sunvisors + rear view mirror $10
r33 all seatbelts $10
r33 wiper arms $10 both
OR GET EVERYTHING LISTED ABOVE FOR $50
pm me an we can arrange pickup or call 0411241499
pick up is in Wollongong
https://www.sau.com.au/forums/topic/382680-cheapest-r33-parts-on-sau/
  • 3 weeks later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
