Well its new o2 sensor time and most state that its fine for rb25 but alot dont mention if they work with rb20's
http://www.ebay.com.au/itm/NEW-Nissan-R33-Skyline-NX-N14-N15-Pulsar-Oxygen-Sensor-/150616354975?pt=AU_Car_Parts_Accessories&hash=item23116f309f#ht_2886wt_1270
will this be fine ?
Edited by reeceo21
https://www.sau.com.au/forums/topic/383071-rb20-o2-sensor-the-same-as-an-rb25/
I think they are different. My o2 sensor went on my rb20 and I threw a 25 one I had lying around and the car ran rich as hell black smoke out the back just buy the right one or sr20 is the same
sr20, rb20 and rb25 all have the same part number. if the rb25 one you put in made it run rich as hell, then the sensor was faulty.
It was brand new plus if you go to repco and ask they don't have the numbers only sr20 ones. Rb20 o2 looks different to the rb25 o2
when i went to get one from autobarn for my r33 a few years back the NGK catalogue listed R32, R33 ones and the part number was the same as the one for the SSS pulsar (natro sr20), plus the part numbers on websites such as kudos motorsport are the same.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
