What did everyone think of the efforts at the final drag meet for 2004 the other weekend? That little 4wd that nearly rolled spun me out!!! Was a bit disapointed with the skyline though. Started awsome, heaps off smoke, got into 4th I think by the sound of it, then spun and that was it. Anybody know what happned to it?
Was for sale. Sounds like its got the goods. If it the one in the trading post in Hobart it would want to go for the price!!!!
https://www.sau.com.au/forums/topic/38354-burnouts-at-drags/
i think he was talkin $28K is that right? he is from launceston.
apparently it just lost drive, wether it was a diff or gearbox dunno.
its not that great a car, only runs 13s. its got fully rebuilt rb25 with forged internals, custom plenum, top mount T04 external wastegate. sounds like a truck. i like the veilside rims
https://www.sau.com.au/forums/topic/38354-burnouts-at-drags/#findComment-779765
Good engine the old rb20's. I put one in a vl and was very happy with it. Never did get around to changing the diff ratio. Otherwise it was the same as another skyline that belonged to a good mate Mick from Speedy Tyres in launceston. His old red beast ran a best of 13.3 with truck front mount, 3 inch exaust and 14psi.
Now if only I could cram one in somthing lighter.
https://www.sau.com.au/forums/topic/38354-burnouts-at-drags/#findComment-792342
Yep. Been out driftin in it allready. Goes really well, but will go even better soon. Should get into the hi to mid 12's. Will be suprised if it dosent. Its nothin special to look at but looks wernt hi on his list. Its go some good gear in it. Hes lookin for some coil overs at the moment. Drop in and see him if you know anybody or let me know through this forum.
Thanks
Matt
https://www.sau.com.au/forums/topic/38354-burnouts-at-drags/#findComment-799391
yeh he took me for a run in it the other night, damn speed cut!
yeh i was talkin to him about the coilovers the other night, dunno if i swayed him or scared him!
yeh should do 12s when he has it sorted, pulled 160 rwkw's at reid racing last thursday, on 12psi pretty good considering still has factory ecu!
https://www.sau.com.au/forums/topic/38354-burnouts-at-drags/#findComment-801051
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
