Yeah, I like the body styling, altho interior I suspect will be as bland as other Toyotas... Unless someone recolour some trim parts with other colours like silver or woodgrain... depends on which style they want..
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62323
Originally posted by skyzerr33
nope
the orignal version of that engine (mk3 supra and soarer) had the twin turbo's. in later model cars ie the jzx100 they dropped the two small turbos for a single larger one. its more responsive and less laggy aparently.
then, how come all the jzx100s listed at j-spec auction data are twin turbos???
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62661
I think the single turbos were pretty dam rare. The 92 supras had singles and they got vvTi as well. Most of the 1jz's out there are twins dunno why maybe they started concerntrating on the 3.0 2jz and gave up on the old tech.
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62685
Even on some supra lots of ppl modify them into a single turbo conversion, as it is far cheaper than buying two sets of turbo and a good single turbo will do the job well.
Alternatively, I think it won't be long until someone stick in a twin turbo charged 2JZGTE engine from a Supra into a Chaser JZX100... Dunno if that can be achieved as gearbox mount, driveshaft length etc could be different. But the engine bay suppose to fit as it looks larger than a Supra.
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62692
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
