They are Super Advan Racing Mags
Good Condition
Sizes are 17x8 Fronts (235x45 17s Dunlop SP 9000s 50% [Very good Tyres!!])
17x9 Rears (255x45 17s Nankang NS-II 30%)
They are currently on my r33 gtst... and are 5x114.3
Price: offers above $1500 with what tyres are on them.
Want perth buyer... interstate pays for delivery...
they will fit on other cars with the same brakes and gtrs and stuff like that alike... like r32s, r33s, s14s, s15s.... i think thats right.... if im wrong please correct me... :spank:
Cars im pretty sure they fit on, r33 gtst, r32 gtr, s14, s15.....if anyone else knows of any other cars they will fit on please let me know.... :D PS. r33 gtst has huge brakes, so you should be safe with offset for other cars with 114.3x5 aswell....
The reason i want to sell them is because i think i want some white mags... :D
Contact:
On this thread...
Mobile. 0429883032
Email. [email protected]
https://www.sau.com.au/forums/topic/38394-advan-racing-mags-17x8s-17x9s-perth/
omg i love enkeis
yes i would swap
but depends what model, size (width)
enkeis are quite thin and most of them are 8s and i want min of 9s on the rear thats why i didnt buy enkeis again, because i couldnt find any good looking 9s. :rant:
ps. email sent....
Hi fane,
i too have had the "white boy bug" its great. Just a lil tip, if u have a certain type of rim you want, you can always get the rims sandblasted, primed and powdercoated in a variety of whites (pearl, bright etc) i got it done on a set of 16s for my old ET and they came up a treat! even fixed the small gutter rash that one of the rims had. Finish was immaculate! I payed 60 per wheel. Its cheap and easy! Also, many places have heaps of colours.....including bronze, gold and even pink!! If u keen, let your fingers do the walking....
Just an idea.
Haro
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
