Hey people, wondering if anyone would be able to help out. Trying to get my clutch pressure plate rebuilt by direct clutches but I have run into problems.
1. My 34 is a daily and I cant really go too long with out it
2. I live in Canberra ( some say that is a massive problem)
Does anyone have a spare stock R34 Turbo clutch plate around that they dont want? Im happy to pay cashmoney. Could we even work out a deal for you to drop it off at direct??
Thanks heaps people,
Steph
https://www.sau.com.au/forums/topic/384056-wtb-r34-gtt-clutch/
That's an easy fix. Ring NPC and order a new clutch and stop stuffing around with second hand shit that won't last as long.
Their number is 07 32779403.
Once you have ordered your clutch you may sit back and wait for it to arrive. Maybe even have a Piña colada and feel good about the fact you won't have to worry about anything except what tyres to buy next because the upcoming skids will be awesome.
I recommend Federal
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
