Hey all, I bought a Canon 600D back in August and am already thinking about upgrading to a more professional camera.
It's in perfect condition and have taken about 3000 shots but can confirm later.
Looking at around $800 just for the body and charger comes in the box and CD's and strap.
If anyone is interested pls PM ME
Located in Hills area Sydney.
Edited by GTR32X
https://www.sau.com.au/forums/topic/384237-canon-600d/
A 7d has more 'nick-nak' features, otherwise the only main things it would be an upgrade from is higher fps, the very slightest low light upgrade. Same image sensor.
The 600d is a great camera... Upgrading to anything other than a 5d or a 1d isn't really an upgrade.
https://www.sau.com.au/forums/topic/384237-canon-600d/#findComment-6131064
Get a good lens - you will then see how good your camera really is. If you upgrade to a 60d... the upgrades are very minimal.
Have a look at: http://snapsort.com/compare/Canon-600d-vs-Canon_EOS_60D
If you want better image quality etc... 5d or 1d otherwise I wouldn't bother
https://www.sau.com.au/forums/topic/384237-canon-600d/#findComment-6131738
I take a different view. A 60D I wouldnt bother with - a 7D I would. The 7D has alot of good features it is not just about sensor size.
Yet to see what the 5D mk 3 has to offer. If you are not in a rush maybe wait for that & if it is not what you are after the 5D Mk 2's will be cheaper by then. A 5d is a balls achingly good camera for the money.
Edited by djr81
https://www.sau.com.au/forums/topic/384237-canon-600d/#findComment-6131861
I am using the 7D, and I wouldn't upgrade to it from a 600D.
Not sure about you, but if I upgrade the camera, I want better photo quality (Not talking about crop size). When I upgrade, I look at image quality, then I look into the small features
https://www.sau.com.au/forums/topic/384237-canon-600d/#findComment-6133192
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
