  • Replies 5.5k
Posted Images
4 days on Fangio grandstand.
Not sure if I want the stand, so may sell off and move stands if I can be bothered.
Being on Jones was pretty good on Sunday.
Brabham was pretty good, but the afternoon sun would be hell during the main race.
We got it for Practice but overcast the whole day which helped.
Clark was terrible, pretty bad view. In the open, whole day of sun.
The grass mound on the left would have provided better viewing.
we were in Brabham but ended up viewing from the Johny Walker bar platform and off brockies hill turns 9-10 and into 11 for some of the suport races. mixing it up was definatly a good option. the sun was a pain but wasnt a big drama for the race. was suprised how effecient the trams were by sunday. friday was by far the worst day for trams.
very pissed with the orginsation of the GP advantage pit walk. as were plenty of other peope we bumped into. missed it due to no one haveing any idea where to go. was in the end told the wrong spot and waited there for half hour. was suposed to get a detailed email regarding details and never got it.
was a good weekend with plenty to see and do at the track. not sure id rush back next year thoe.
Brabham was hard work looking into the sun on race day.
Jones definitely the better stand since you have the sun behind you and can see part way down the main straight as well as turn 1/2.
Schumacher stand is actually really really good. screen right infront of you, can see the final two corners, pit entry and most of the front straight.
Or the Waite stand at the high speed chicane, excellent value for money, plenty of action and right next to all the food and entertainment
Saw turn three has a stand too now, but its a bit far away from everything. Good action on track though
what. to. do.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
