  • Replies 47
Posted Images
I was going to make it lower but a bit wider 10mm base 3 inch pipe for the sides with a top plate 3mm. I starting planning it out just need to work out volume it will be I'm aiming for 5.5 but see what happens hard to figure out
Ok so after a shit load of reading and smoke breaks iv come up with my design simular to some plenums but different as well. It turns out the the plasma man plenum didn't do much other then store more air then stock. The reason for more response is the fact the air doesn't turn back on itself so when the valve closes the air that wasn't consumed pulses back up the runner causing turbulence. So removing the bend allows the air to pulse back into the chamber faster causing less turbulence so quicker response very simple really. So plenum size is the next thing smaller smaller the plenum gives more resonce due to increased velocity. larger the plenum means more air up top more power but less midrange. Now I want everyone's opinion seriously. Would you rather want more power between 3500rpm and 6500rpm or 5000rpm to 8500rpm for a street car? Prob should start a poll on this that way I can make a plenum to suite street and one for track. I'll start fabing one soon
Edited by Bsa
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
