Selling this 4 channel amp due to upgrade. Used for like 3 months. Bought for $400 brand new from autobarn. Minor scratches. This is a high quality amp! Just google some reviews on it. You wont be disappointed. Asking $200 or nearest offer. All reaonable offers considered. Pick up only from roxburgh park or oakleigh. Sms me on 0433091345 any time for a pic.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
