Selling this rare asus vx7 brand new in the box, they come with swarovski crystal. Bought the laptop for $2700 and spend another $1000 to put the swarovski crystal on it. Receipt will be provided for the laptop. reasonable offer may considered, anyone interested can just message me and leave me your contact number. Price $3500 ono.
Model: Asus VX7-Orange
Screen size: 15.6" 16:9 Full HD (1920x1080) LED backlit
CPU: Intel® Core™ 2nd Gen i7 2630QM
RAM: 16GB DDR3 1333 MHz SDRAM,4 x SO-DIMM socket for expansion
Graphics: NVIDIA® GeForce® GTX 460QM with 3GB GDDR5 VRAM
Storage: 2 x 750GB 5400rpm/7200rpm
Optical: Super-Multi DVD
Blu-ray Writer
Blue-ray reader
Wireless: Wireless-N (b/g/n) / Bluetooth v2.1
Interface: 1 x Microphone-in jack
1 x Headphone-out jack (SPDIF)
1 x VGA port/Mini D-sub 15-pin for external monitor
1 x USB 3.0 port(s)
3 x USB 2.0 port(s)
1 x RJ45 LAN Jack for LAN insert
1 x HDMI
Audio: Built-in 2 Speakers And Digital Array Microphone
Built-in Azalia compliant audio chip, with 3D effect
Webcam: 2.0 Mega Pixel web camera
Battery: 8Cells : 5200 mAh 75 Whrs
Dimension: 40.2 x 30.9 x 5.00 ~5.79 cm (WxDxH)
OS: Windows 7 Home Premium 64bit
Can the crystals come off without damaging the surface?
Hi... yes you can take the crystals off without damage the surface. Just have to send it to profesional to do it.
Price drop $3000 or reasonable offer considered, anyone interested can just pm me.
Edited by Hoshima
  • 4 weeks later...
Guest
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
