FOR SALE - 1989 Nissan 300ZX Twin Turbo 2+2 Targa
3.0L V6 Twin Turbo - VG30DETT
4 Spd Auto
2 Door Coupe (2+2 Targa)
Black
Un-registered
No RWC
Can register for right buyer
102,636 kms on body
Freshly Rebuilt Motor (still being run in 5,000 kms on motor)
High-flowed Turbos
Re-gassed Air Con
Brand New Battery
(Two separate invoices for about $9k worth of work done on rebuild of the motor and turbos)
20 x 8 on Front with 235s
20 x 9 on Rear with 255s
Adjustable Coilovers in front end
After market exhaust
Blitz computer
Standard turbos rebuilt and hiflowed
New Nissan Purple Injectors
* Motor runs perfectly just like new after rebuild and new turbos.
Bad Points:
* Few body blemishes and could do with a respray
* Brake lights seem to be staying on (may need new switch behind pedal)
* Power steering bearing is gone, noisy when turning
PRICED TO SELL!!
$5,500 ONO
COME AND INSPECT MAKE AN OFFER!!
https://www.sau.com.au/forums/topic/384571-1989-nissan-300zx-22-targa/
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
