Wasn't a bad day out... track temperatures seemed a bit hot, managed to find a couple of loose hoses which are now addressed.
Was going to call you Pete but didnt have your number on hand, didnt get there till 11.30am or so...
Hardly anyone turned up in the morning. Good but cause get more track time to ourselves. Only got held up in the second session by some Commo's.
Afternoon more people, but still got some very good runs. Gotta do something about the engine temperature though.
This is my last outting with the arrowz for a while now. Gotta get a proper intercooler and a Power FC.
Guest Diabolik1
I came at around 2:30pm
Saw a R33 GTR in the garage, a grey R32 GTR and a Gunmetal grey R32 GTST (Morgs, i think it was yours but didnt see ya anywhere)
I left after about 30 mins...no 'lines were on the track, only a couple of V8s, a red Type R, red WRX and a Yellow BMW...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
