  • Replies 46
Posted Images
read somewhere close to 320hp at the wheels
officially 280hp
R34 GTR in standard form is pretty slow and very laggy to my liking
which is why no keeps them stock
Wait what?
280hp at fly but yeah around 320 at fly, around 230-250 at wheels if totally standard.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144241
Stock Standard R34 GTR's have been proven on many different occassions to make around the 320 all-wheel horsepower mark. Nissan quoted them as 206kw due the "gentleman's agreement" but in reality they made about ~50-60 more hp than quoted.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144591
Flywheel horsepower. Not wheels.
Show me one stock standard R34 GTR making 320awhp.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144615
This dyno sheet is of my car with and without the intake snorkle removed. Car was bone stock, down to intake and exhaust but had it's boost restrictor removed.
So in regards to the OP's question, on a stock standard GTR with snorkel and boost restrictor still in place, I'd have to disagree here mate and say that 320AWHP would a very optimistic figure. pinch.gif
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144683
Looks around about 270awhp / 201awkw with the snorkel in place. Agreed, 320 is rather optimistic to say the least.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144766
Mine ran around 12.5-13 PSI with restrictor removed, so yeah around 1 bar.
It would depend on flow of air filter/exhaust etc. So anywhere between 12psi to 15psi. Hence why it's always a good idea to get the AFR's checked when you remove it.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6145334
I've seen it on a Nissan Skyline documentary. It showed a bayside blue R34 GTR non-v-spec on a dyno and it made between 310-320awhp. I can't remember to exact figure; I watched this doco a long time ago =\
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6146135
Was this "documentary" hosted by Ketzal Sterling? :whistling:
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6146237
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
