  • Replies 46
Posted Images
read somewhere close to 320hp at the wheels
officially 280hp
R34 GTR in standard form is pretty slow and very laggy to my liking
which is why no keeps them stock
Wait what?
280hp at fly but yeah around 320 at fly, around 230-250 at wheels if totally standard.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144241
Stock Standard R34 GTR's have been proven on many different occassions to make around the 320 all-wheel horsepower mark. Nissan quoted them as 206kw due the "gentleman's agreement" but in reality they made about ~50-60 more hp than quoted.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144591
Flywheel horsepower. Not wheels.
Show me one stock standard R34 GTR making 320awhp.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144615
This dyno sheet is of my car with and without the intake snorkle removed. Car was bone stock, down to intake and exhaust but had it's boost restrictor removed.
So in regards to the OP's question, on a stock standard GTR with snorkel and boost restrictor still in place, I'd have to disagree here mate and say that 320AWHP would a very optimistic figure. pinch.gif
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144683
Looks around about 270awhp / 201awkw with the snorkel in place. Agreed, 320 is rather optimistic to say the least.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6144766
Mine ran around 12.5-13 PSI with restrictor removed, so yeah around 1 bar.
It would depend on flow of air filter/exhaust etc. So anywhere between 12psi to 15psi. Hence why it's always a good idea to get the AFR's checked when you remove it.
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6145334
I've seen it on a Nissan Skyline documentary. It showed a bayside blue R34 GTR non-v-spec on a dyno and it made between 310-320awhp. I can't remember to exact figure; I watched this doco a long time ago =\
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6146135
Was this "documentary" hosted by Ketzal Sterling? :whistling:
https://www.sau.com.au/forums/topic/385189-r34-gtr/#findComment-6146237
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
