S15 silvia crashed wrecking bits i dont need
Manual conversion 89,000K on the clock runs great has brand new couple of day old 5 puk HD Excedy sprung buton clutch, good flywheel, 6 speed gearbox which is not noisy and feels great like a new car, comes complete with tailshaft slave cylinder clutch master cylinder pedal box and everything else needed including gearstick boots.
$1800 ono really easy conversion to do and if local can even help out with work.
Front and rear seats, plastic broken on outside of passenger seat but no rips stains or tears $450 for all.
Dashboard cluster 89k if you wanna do the dodgy lol $150
Rear helical diff $450
Air bag in dashboard $250 ono
Steering wheel with airbag $350 immaculate condition
any other parts needed just let me know but i am using most of whats not listed but try your luck anyway....
All located in Windsor NSW
can arrange freight for anything.
Tim
0404321205
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
