  • Replies 49
as long as your radiators getting sufficient air flow and working really well and your oil is staying cool if its meaning getting a bigger core and moving it to get more air flow then you shouldnt have any problems with "Air pressure" being an issue. Its not like im wanting to do superlap around eastern creak and every bit of R&D for carbon bonnets is vital for my engines survival, especially for a daily driving car. That said all Im after is to get the temp in the engine bay down so the intake isnt chocking itself. I personally dont think it matters where vents are as long as it works temp wise and you dont get water damage to coil packs.
And how much research have you done into the subject to be able to make claims like that? I've personally seen 3 cars with cheap vented bonnets that had huge issues with over heating. Admittedly none of them in the Z-Tune design so perhaps they don't have the same issues, I don't know.
As I've said in numerous threads now, the cheap bonnets won't have the R&D in them to have a design that doesn't cause problems with low pressure zones. So in actual fact, with cheap bonnets you will most likely notice an increase in temperatures.
Really so why comment on my post about z tune bonnets and there cooling efficiency if you don't know.
Aluminium factory bonnet.
Carbon not necessary.
Weight savings minimal..
Exactly. A Ally bonnet is that light compared to a carbon one. There is sweet FA weight difference in it.
Cf z tune copy bonnet was much lighter then the oem Gtr r34 bonne when I felt them both to compare., for full track car, I'd go the cf bonnet. For the street, stick to oem. It only gives you extra rep cool points for running a cf bonnet on the street
Do you know that they don't cause any problems?
Edited by Hanaldo
I personally don't have experience with them but im not saying they dont have issues. As stated above if you dont know about a certain product that i was talking about, then dont make claims about it.
And i know of a few gtrs that are running them without any problems except water drainage and do provide cooler engine temps but I'm not backing the copies and there cooling efficiency untill I have tested myself.
This is exactly what I was saying, why get up in arms about it just because I said it?
And lets be honest Hanaldo... If "pressure zones using R&D were so critical with engine bay temps for a normal daily road cars, why do you see so many cars driving with say no bonnets, aka rotaries and hot rods etc, so many drive with out bonnets to 1- show off and 2 - keep engine bay temps down. Ive never seen a car with over heating issues from using a C/F bonnets in various designs on any car if you have your cooling systems working good.
I recon 9 times out of 10 they are only for looks thats it. My sti bonnet weighed 13kg and my Cf bonnet for it weighed 11 kg there wasnt much in it so really theres no weight advantage unless you go twin layer CF or so which would be no use for the road because of crumple factors in a crash.
im just going on facts of what ive seen and heard, obviously i havent owned every cf bonnet in the world but at the same time in NZ they are very common and its not hard to see and talk to people about their experiences.
This is an outrageous statement, jus' sayin.
Gonna have to disagree on that one mate. To me, it felt like there was only 1-2kg difference in weight. The stock R34 GTR bonnet is VERY light.
all high performance jap cars bonnets are light, Evo's, STI's, GTR's Honda Type R & NSX they are all light alloy bonnets and it would be difficult to find an off the shelf CF bonnet genuine or not to be significantly lighter than them. Especially one that would be considered legal or even safe enough for the road. I would consider 10-13kg light, I bet my gts-t bonned weighs an excess of 20kg hahaha actually does anybody have an idea in the weight lol?
Yes, I agree with you on this one. I just tested some CF bonnets and Al ones and you're right - not much of a huge difference. The truth is, most people choose to go vented CF bonnet for looks more than performance.
Depends a lot on how the CF bonnets are made though. If they used a lot of layers or didn't get rid of enough epoxy resin then the weight will add up. The resin actually weighs a hell of a lot, usually the peel ply they use to absorb the excess will way a lot more than the entire carbon fiber structure.
I'm talking about the 100% CF ones - all copies and half FB ones are disregarded as they're still quite heavy and are just for show.
So am I. Making carbon fiber is not an easy thing, you need a fair bit of experience to get a top quality result. It's very very easy to use too much resin or not soak up enough excess or build too many layers etc. and then all of a sudden you have a carbon fiber part that is heavier than the part you took off. Don't take it for granted that a 100% carbon fiber part is going to be light, it depends on how it was made.
That said, I'm sure the big companies churning out CF parts all day long know what they are doing. But you pay for it. Carbon fiber is expensive to make and therefore expensive to buy. I wouldn't be so confident that the cheap CF parts you see will be so good. Then again they might be. Its a gamble. Look at this for an example:
http://www.skylinesaustralia.com/forums/topic/375265-r32-dry-carbon-partsdoorsbootbonnet/
$4000 for doors, $2000 for boot lid, $2000 for bonnet, $3500 for dash... That's how expensive it is to make quality carbon fiber parts.
Gtst bonnet approx 19kg Gtr is 10kg big difference!
Pls read this thread for comparison between full cf bonnet vs oem Gtr r34 bonnet - 6.2kg saving :)
http://www.skylineowners.com/forum/showthread.php?t=160652
LOL far out ^^^ I guess im not surprised, its an effort just to lift it haha. even the cheap common (heavy) cf bonnet would be a big weight saver. Still im after the vents for cooling rather than the weight purpose. maybe 1 day.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
