  • Replies 46
Hopefully I can go to this... Will depend on the date for me.
Any chance we can turn this into a V - Z track day at Wakie or somehting?!
Would give us all a chance to meet and greet and to go above & beyond "spirited" driving on public roads without the cops. Plus I'd LOVE to see which set up can crack the best time.
I live on the coast so ill look around see what i can find for an easy place to use as a meeting point and to have a bit of a show and shine, Terrigal haven comes to mind as there is some pay BBQ's there but it can get very bussy on a weekend.
Track day is out of the question. Not all of us, especially me have track ready cars. Maybe later on down the line.
T4NK- if you could that would be great man. I was thinking Aus Grid stadium car park in newie then a cruise to wisemans ferry or something along those lines
hmmm we could go under the bridge in gosford near bluetoung stadium there is a medium size car park there its on the water front would be good for pics with the water behind the cars. Only issue is u get some bogans around there sometimes lol.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
