Hey guys,
got a couple of things im trying to get rid off to fund my build.. Parts are off my Gtt and a r32 Gtr head..
1) Standard Gtr camshafts $100
2) Standard Gtr Cam Gears $50
3) R34 Steering wheel $120
4) Optima yellow top battery $210
5) R34 Coupe Rear seats $100
6) R34 rear quarter plastic trims $100
7) R34 front guards (white will not separate) $400
8) R34 series 1 front bar (really bad paint) $free
9) R34 Interior carpet (has wholes due to roll cage in the back) $100
10) R34 Rear parcel shelf $40
11) R34 Boot Carpet $50
12) Stock arms (castor rods, camber,..) $40 Each
13) Stock Air box with snorkel $160
14) Stock boost solenoid $20
15) Stock dump pipe and front pipe $40
16) R34 Radiator $50
Happy to ship all items at buyers expense.
Please send me a msg for pics and il take some on request..
Located in Mordialloc VIC
Please pm or sms during bus hrs on 0432647023
Cheers
Herb
  • Replies 41
18) R34 Gtt Bonnet Hinges $50
19) R34 Gtr-Gtt Bonnet Latch $50
20) R34 Spare Tyre $50
21) R34 Passenger Kick panel with flare and bracket $100
22) R34 Rear Seat Belts $70
23) R34 Std Cat Converter $20
24) R34 std dump and front pipe $50
25) R34 Auto Cluster with around 120,000 kms from memory $100
26) R34 std gauges $50
Cheers
Herb
Hey guys,
3) R34 Steering wheel $120 $100
7) R34 front guards (white will not separate) $400 $370
Cheers
Herb
Edited by GTXR34
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
