R32 FULL LENGTH COOLING PANEL, GARAGE DEFEND TYPE. $400
HKS T51R KAI BB TURBO KIT, WAS REBUILT BY GCG IN JANUARY, ALTHOUGH IT ONLY DID A FEW DYNO SESSIONS THEN I DECIDED TO GO BIGGER.
HAVE THE RECEIPT ASWELL.
INCLUDES TURBO, MANIFOLD, WASTEGATE, DUMP PIPE
$5500
LOCATED IN SYDNEY, PICS TO COME BY MONDAY
THANKS
Edited by SRB
  • 3 weeks later...
  • 1 month later...
  • 2 months later...
  • 4 weeks later...
  • 1 month later...
