  • Replies 42
It means it was, from factory, a Non Turbo car.
Now that means the person you bought it from, who told you it was an "EX-Turbo" had gone and turbo'ed a non turbo car, then removed it all and sold it as stock non turbo again.
This isn't as bad as a Turbo car that had been neutered of its turbo and running low compression.
You do not have a 25GT-V but you do have a 25GT. Still, that's good news for you. thumbsup.gif
More likely it means the seller didn't know what they were talking about. Probably thought that all Skylines are turbocharged so this one must have been deturboed.
That's what I'm thinking too. But then again, some the habibs and morons out there would be stupid enough to go to the trouble of turboing an NA and unturboing it.. lol..
I'm thinking the same as you though Hanaldo. It's probably just a factory non turbo stock as a rock. They hype it up to people who know nothing about cars by slipping that magical word in. 'turbo'
Very nice, & welcome !
Love the Nismo front bar - looks very very nice with the wheels, in blue.
If you get sick of the wheels one day down the track simply powdercoat them white, would look even better IMO & is pretty cheap to do.
R34 Nismo-kit side skirts arnt expensive, if you can find them, & would finish off the 'looks' very nicely.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
