1st up is a basically brand new genuine HKS super sequential III blow off valve and RB25 adapter had it on my car for a few laps of my block but my cars idle was all over the place so took it straight off again and threw it back in the box(car wasnt tuned with atmo BOV) $250ono
Next is a brand new in the box genuine HKS inlet cam gear i bought but never installed $220ono
Genuine used GTR fuel pump that was in perfect working order when it came out of my car my car was making 266rwkw on PULP and this pump was JUST hanging in there so i replaced it with a Tomei unit $50
Brand new in the box Nismo FPR went on a spending spree and turned out i didnt need it! $150 firm
Brand new malpassi adjustable FPR $100 firm paid $300
Used( but in great condition) ARC airbox and filter bolts straight into an R33 fits Z32 and RB25 AFM $250ono
Brand new in the box BMC cold air intake and filter basically its filter with cold air line that clips straight into the front of the Pod type filter i paid $320 for this setup but its too long for my setup would probably suit a non AFM setup only its a pretty trick setup spewing it was too long $250ono
Last up is a set of 19" black meshy type speedy rims that i have will post pics up again but you can find em in here if you search my content $400ono
Please contact Mick on 0423089277 or PM me email addresses if you want pics as its easier to MMS or email them than to go through the photobucket business
will post pics up tomorrow PICK UP PREFFERED!!!:thumbsup:
https://www.sau.com.au/forums/topic/386653-rb25-parts-for-sale-in-sydney/
  • Replies 76
Bought a Link G4 today considering selling my Nistune to suit a 33 RB25 only throwing this out there but if i get the right offer ill part with it so throw me some offers :thumbsup:
Been tuned by Yavuz at unigroup for a GTX3071 making 288rwkw on bout 21psi
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
