Rang up j/c insurance today checking if it was ok to cut out my front bar for a fmic and they said... "we will cover anything as long as its legal"... which got me thinkin... Does that mean that if i crash and make a claim it will void my cover for having a BOV, turbo timer, boost controller etc...? which i have told them i have on my car. Any1 know the deal with this?
ps. is it legal to cut ur front bar? i got a 32 type m bar and wanna cut it up to level with where the liscence plate finishes and move the plate down to 1 side.
https://www.sau.com.au/forums/topic/38688-sly-insurance-bs/
its a funny quesion that one, as over in sa, things like bov are illegal whilst quite acceptable interstate. I think as long as u have already listed the modfications made to the car, u will be fine.
I know of alot of modifed cars that have had payouts or been repaired which have had "illegal" mods.
https://www.sau.com.au/forums/topic/38688-sly-insurance-bs/#findComment-783622
It comes down to the assesor really, and how hard they want to try to get out of the claim.
If your car is in a state that renders it illegal under the laws of the state you are driving it in, then driving your car is an illegal activity.
Your policy will contain a clause stating that they reserve the right to void the policy if being used for illegal activity.
This means that, if you have an atmo BOV in SA, your insurance company CAN void your policy. Not saying that they will, but it is within their rights, as they state to you in the disclosure statement.
https://www.sau.com.au/forums/topic/38688-sly-insurance-bs/#findComment-783825
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
