Marulan T-T is the ultimate time trial experience!
An exciting way to enhance your driving techniques while enjoying an interactive challenge.
All experience levels are welcome as drivers will be grouped by lap time on the day.
Each driver will dial in their own time at the start of the day and aim to match it during each session. Consistency is the key to improving your driving skills and techniques!
There will be Advanced Driver Instructors there on the day to offer tips and advice for those looking to take their driving to the next level!
When? Saturday 25th February, 2012
Where? Marulan Driver training centre
Contact JMP Motorsport - [email protected]
Price $185 per driver
www.jmpperformance.com.au
Click here to download the Marulan Time Trial Info Pack
https://www.sau.com.au/forums/topic/387271-marulan-time-trial/
Shane,
48 seconds is fast for the Echo!!
I did 46 in the MX5 back in 2009(wife did 51 in it)think I could get low 45's now.
I recall badhairdave did a low 43/high 42 in his track S13
can I borrow someones superkart for this? hehe
  • 1 month later...
Just one week to go guys! We're very excited to get out there on track!
We have a few spots left to fill, so if your keen to get out on track head to the website to book - http://www.jmpperformance.com.au/events-2/
Big thanks to our new sponsors as well - Just Car Insurance!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
