pfft. f**k gettin scared away from all the fun times associated with car shows/scene.
also when do we find out if weve been accepted?
  • Replies 85
That's excessively paranoid.
I'm happy to display my car in public. I don't paint my address on the windshield, I don't tell people what type of alarm it has, I don't tell them how often I drive it, where I drive it, nor where I park it.
Then when I'm done not telling people what I do with my car, I get it home, park it in a lock up garage, arm the alarm, and sleep peacefully knowing that should the worst come to pass, Adelaide is a small place, and it's fully insured... Just in case.
None of my Skylines ever got broken into nor even close and every one I've had has been regularly entered into show and shines and driven on a near daily basis.
for peace of mind i swap my plates to another set of plates i have here, and put a little bit of tape over the vin number etc. and ive never had any theft related issues
haha yeah a bit paraniod. i used to be in a couple clubs that would regularly have parts stolen from the display cars, even while we were standing there guarding them... small car sunday, autosalon, here and interstate....
Edited by Deep Dish V35
I have had my cars in about 200 shows around the country and have never lost a thing off them , i must be very unlucky !
Unofficial cruise from my place at 7am :) if you don't know where I live, don't ask, just be somewhere along North East Road just after 7am and listen for the rumble...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
