Rather than post up a new thread iwth a new question ever few days, why don't you save up a ton of your questions about every aspect of V35s and ask them in one thread? This is getting a bit ridiculous.
And before you post another new topic every time, make sure you do a search on SAU for the topic, and go do a search on g35driver.com - you will find that every question possible of being asked has been asked on there.
https://www.sau.com.au/forums/topic/388297-tallights/#findComment-6188922
I assume you are referring to a sedan...and I assume you are referring to headlights not tail lights...if my assumptions are correct, then the answer is NO. S1 and S2 headlights are different.
Edit, just re-read your title...tail lights, yes they are interchangeable...
Edited by n15m0
https://www.sau.com.au/forums/topic/388297-tallights/#findComment-6189496
Believe it or not we actually did have a like button on the forums about a year ago, but we took it off because people were abusing it. There was a reputation rating of each user as well, and when you got too many dislikes your reputation went down the toilet and there were too many idiots abusing it, so we removed it.
But yeah, when a user has 6 threads on the front page of any forum it is time for me to tell them to calm down. Especially when most of the the topics have been covered before.
Thanks for the 'Likes' guys :D :D :D .... I am just trying to keep the peace and make SAU enjoyable for everybody.
https://www.sau.com.au/forums/topic/388297-tallights/#findComment-6189893
Well if I asked all the things I wanted in one post it all gets lost in translation and I only get the answer on one or two issues.
I did look on G35driver.com and yes there was a post relating to it but wasn't what I was asking.
I'm new to the whole forums idea because this isthe first real "import" and "decent" car I've had so I'm sorry for asking heaps and heaps of questions
Also nightcrawler, I'm sorry for being a mega C**T to you last night. Had a bad day at work and I took it out on you and that's not mature and acceptable at all. I am sorry.
https://www.sau.com.au/forums/topic/388297-tallights/#findComment-6190015
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
