ive got one but its in sydney! PM Me if it still interests you
I am interested if you still have it and I live at Pymble. Can you please PM me details and price.
Thanks
  • 3 weeks later...
Bump. Please stop offering me $1500 stock gearboxes, they're not worth that much lol
actually they are, u might get lucky and find one for 1000 bux but it would probably crunch, or die after afew thousand k's
and if you really want to know what they are worth just give any jap wrecker a call
lol.
Edit: bump
Edited by Entice
