Great Xmas and start to New Year
Boxing Day driving home from Tauranga to Taupo at 10pm had about 20kg of dog race out from side of road
and despite me braking and going to edge of road to avoid it, dog smacked into front drivers corner of my 300GT
End result:
Bumper replacement approx $1600
Grill replacement approx $350
Headlight replacement $1400
Minor panel damage prob about $200
Labour................god only knows
Now find that the Airbag light flashing after accident means new airbag........................$2500
Dog died at scene
Thank god for my car insurance
https://www.sau.com.au/forums/topic/388551-xmas-2011/
Nuwan @ import revolution in Melbourne has about 10 V35 sedans wrecking, his prices are good compared to new/nisswreck and his postage is cheap!!
$450 for front bumper
$290 for front gaurd
$175 for grill
Hope this helps you out a bit. Just as long as your okay. If you swerved and had an accident you would have been done for neg driving..... Car is fixable, life isnt as easy.
https://www.sau.com.au/forums/topic/388551-xmas-2011/#findComment-6192735
From what i understand Airblag flashing doesn't mean you need a new airbag. (I have a solid Airbag light which i'm sure is far worse).
Google ways to stop the airbag light flashing, its fairly straight forward. Just turning car on / off a certain number of times.
https://www.sau.com.au/forums/topic/388551-xmas-2011/#findComment-6192933
Yeh my m8t had that issue in his 33 GTST there was some sensor on the door he played with a few times to fix it, maybe there is something similar or even an ECU reset might help unplug ur battery for 30min to an hour to reset it im not sure of another way to reset it.
https://www.sau.com.au/forums/topic/388551-xmas-2011/#findComment-6193148
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Ignition Key Method:
1) Turn IGNITION on (but don't start car)
2) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
3) Wait 4 seconds
4) Turn IGNITION on (but don't start car)
5) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
6) Wait 4 seconds
7) Turn IGNITION on (but don't start car)
8) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
9) Wait 4 seconds
10) Turn IGNITION on (but don't start car)
11) Wait 3 seconds
12) Turn IGNITION off
13) Wait 2 seconds
14) START Car (the light may be blinking slower than before)
15) Wait 3 seconds
16) Turn IGNITION off
17) Wait 3 seconds
18) START Car
Source: http://g35driver.com/forums/repairing-detailing-diy/163319-diy-airbag-reset-instructions-03-07-g35-coupe.html
https://www.sau.com.au/forums/topic/388551-xmas-2011/#findComment-6193506
Its the Insurance company that decided to replace the airbag
When the panel beaters took the car to the Nissan agents to check the flashing light, they were told that the airbag
had developed a fault and needed to be replaced
I guess it must have been the accident as it was one helluva thump. I was just surprised the thing didnt go off
Unfortunately the airbag has to come from Japan and costs $2500 worst part is that it takes about 2 weeks
As has been said in an earlier post, " Car is fixable, life isnt as easy."
Just glad we werent injured, there was a big ditch on the side of the road which would have rolled us had I gone any further off road
to avoid the dog, I saw the ditch coming and couldnt do any more to avoid the dog
https://www.sau.com.au/forums/topic/388551-xmas-2011/#findComment-6195603
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
