Came off my V35 Coupe Skyline, VIP wheels
19" Work Varianza F2s
19x9.5 +10 fronts (60mm dish) with 235/35/19 federal 595 SS 85% tread
19x11 +4 rears (130mm dish) with 255/35/19 federal 595 evo's 50% tread
5x114.3 stud pattern
Genuine work valve caps
Good condition, slight gutter rash on the front wheels but getting repaired
In the next 2 weeks or so. And a polish.
Will swap for standard v35/350z wheels + cash.
Can MMS PICS, I'll get pics up later.
Location - Brisbane
Price - $3200
Txt/call Bee - 0405 796 118
https://www.sau.com.au/forums/topic/388847-19-work-varianza-f2s/
Assuming that's your car & wheels pictured?
Do these clear the brembos?
yes thats the wheels pictured and my car.
not sure if they clear tbh, will have to check the disk type.
now $2500, need them gone.
  • 2 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
