Correct me if I am wrong (which I don't think I am) - but Windscreens for all R33's are stock standard and are the same size so you just need a replacement.
Now, I would suggest if you cannot get parts from a local wrecker, then Ebay is your best friend. Just type is R33 Windscreen on the global site (Ebay US) and create a "watch notification" under settings and download it onto your smart phone then keep an eye out for it. Otherwise, look at the Sales Section of this forum and get someone to post it off to you when they are wrecking a R33 to Africa. You have to be prepared to pay for delivery either way if you want your window fixed.
Good luck.
https://www.sau.com.au/forums/topic/389408-r33-windscreen/#findComment-6209463
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
