Hi guys,
Selling an Greddy emanage blue piggy back ECU package, the complete emanage blue setup.
The package includes:
Emanage Piggy-Back Blue ECU unit + manuals ect
Plug and play wiring harness/loom to suit rb20/25
Ignition loom
Injector loom
PC Software and USB cable
WILL NOT SEPERATE
$550 ono
(When buying brand new, all the components to this package is not bundled and each must be purchased separately)
It is used, and I haven't used it yet, but the unit was working fine in the previous car it came out of.
Paid $680 for it 2 years ago, Got it all off the SA forums.
MORE INFORMATION ABOUT THIS INTERCEPTOR/PIGGY BACK:
The Greddy emanage is an interceptor/piggyback system that plugs into the stock ECU.
It's a generic remapper for stock ECUs. So if you have a GTR, GTST, Evo, Subuaru etc the emanage can/will sort it out, although this this set-up is for a r32/r33 gtst.
The unit needs a main harness to suit your car (which is included in this package to suit r32/r33 gtst).
Its a stage 1 interceptor which intercepts Ignition, Injector, and all the main sensors to control the car and let you "tune" the main system.
Tuning is done via a laptop which is linked with a 9pin serial USB cable.
The stock ecu is still present so complex things like 4wd, traction control, abs systems etc work just as normal.
This piggy-back works much like a SAFC except this is load vs RPM.
If you are looking for the best bang for buck the basic package of the emanage works just like a SAFC but much cheaper than a PowerFC.
Once installed, you can make relevant changes as needed such as airflow meter changes, AFR tuning, IGN timing etc.
This package is already upgraded with the ignition harness and the injector harness, so there is more tuning options (once upsized injectors are installed) and these harnesses also hook up to the e-01 to tune via the e-01's screen.
Regarding the tuning software, if you upgrade injectors and you already have a basic tune BEFORE the injector upsize, you simply enter in the % increase of the injectors and it automatically adjust your maps to suit.
There are some limits into the size of the injectors you can run and other changes, but all in all a good interceptor unit.
After much research on a remapper/interceptor, I choose the emanage.
Once again, I recommend you speak to a local tuner and see if they have done any emanage units, as different tuners believe in or trust certain ECU options more than others. In Melbourne's south east, I recommend Trent from Chequered/Status tuning, he loves this piggyback, and says one of the best piggy backs around for $$$ spent. You just need to find a competent tuner that works with the emanage.
________________________________________________________________________________________________________________________________________________________________________
ALSO FOR SALE:
If you already have a Emanage Blue unit (or can get your hands on one) I have another small CHEAP PACKAGE to get you going. Package includes:
PC cable
Connecting harness
Burnt copy of the software
$40 ono
With this package you can splice the connecting harness into your cars wiring loom (big job) or get the plug and play harness suited for your car (much neater and easier).
post-62246-0-64133300-1327743946_thumb.jpgSELLING FOR $1000
[/b]
I also have a z32 AFM with plug, scratched but works perfect $150
We all know what and how popular this unit is,
We all know what power this ECU is capable of managing,
We also know they don't make these anymore and are very rare these days,
We also know this won't last long!!!
post-62246-0-43662100-1327744358_thumb.jpg post-62246-0-24410100-1327744413_thumb.jpg
post-62246-0-75003400-1327744468_thumb.jpg post-62246-0-65243200-1327744636_thumb.jpg
MINIMUM REQUIREMENTS/MODIFICATIONS FOR RUNNING THIS UNIT:
Full Exhaust 3" from turbo back
Boost Controller (Bleed Valve/Boost tee or Electronic Boost Controller - Or you can use the PowerFC boost controller kit)
Air filter upgrade / Pod filter or CAI setup kit
Upgraded Intercooler
Z32 Airflow meter (if wanting high power, approx above 210kw)
I MAY CONSIDER Reasonable/Fair offers, (low-ballers and time wasters will be ignored)
Possible delivery at buyers expense. Just check my trader rating and comments.
Please call or sms me, and ill get back to you asap if I miss your call
Located in the North corridor of Melbourne, pick up from Brunswick, Reservoir or South Morang
Cheers,
Ben 0422 782 888
These still available?
What's the spec list for the current tune in it?
Yes, both are still available! Alot of interest, but no one producing the cash!
The Power FC is tuned for:
- Walbro Fuel pump
- 3" turbo back exhaust
- Bigger unknown t4 turbo (kicks in hard at about 4,000rpm)
- unknown injectors (next size up from standard)
- Splitfire coil packs
- Front mount intercooler
- Forward facing Greddy Plenium with 90mm throttle body
- Z32 AFM
But a tune is REALLY, REALLY recommended! The Power FC can be reset and driven with (not far, just to your local tuner) with a basic minor setting adjustment.
- Walbro Fuel pump
- Z32 AFM
Power FC and Greddy PiggyBack STILL AVAILABLE!!!
Any REAL interest and offers out there?...
Many offers are being declined at $800 for the Power FC,
You got $900?... and want to pick up... you got a deal!!!
POWER FC WITH HAND CONTROLLER SOLD, SOLD SOLD!!!
Z32 AFM $150ono
GREDDY BLUE PLUG AND PLAY PACKAGE $500ono
Z32 AFM $150ono
Any takers and or offers?
Greddy Small Package SOLD!!!
STILL AVAILABLE: Z32 AFM $150ono
GREDDY BLUE FULL PLUG AND PLAY PACKAGE $500ono
POWER FC WITH HANDCONTROLLER SOLD, SOLD SOLD!!!
STILL AVAILABLE:
Z32 AFM $140ono
GREDDY BLUE FULL PLUG AND PLAY PACKAGE $450
STILL AVAILABLE:
Z32 AFM $140ono
Bump
I'll take this if its still for sale:
"ALSO FOR SALE:
If you already have a emanage Blue unit (or can get your hands on one) I have another small CHEAP PACKAGE to get you going. Package includes:
PC cable
Connecting harness
$40 ono
With this package you can splice the connecting harness into your cars wiring loom (big job) or get the plug and play harness suited for your car (much neater and easier)."
Picked up the emanage yesterday, all there, cheers! Def one of the nicer traders on sau I've met
Thanks brother!
This man is a great bloke to deal with aswell!! :cheers:
just after the z32 plug, willing to seperate?
Z32 AFM with plug still available!!! as of 8th March 2012
$140ono
(EVERYTHING ELSE GONE!!!)
$140ono
ALL ITEMS IN THIS POST SOLD!! SOLD!! SOLD!!
Thank guys, more items to come, stay tuned...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
