Hi Guys
I have done a bit of a search but nothing is mentiond about getting the E-brake on the 5 speed auto to lock the rear wheels, my parents bought me a drift lession BYO car at eastern creek for christmas and my hand brake does notihng. I have taken it to a mechanic on the weekend when i had it serviced and they tightend it for me to no effect to get it to lock the wheels the peddle is much harder to push down now tho, i found a post (shown below) and im wanting to know if its just an issue of not tightning the right spot or if the E-brake is not able to be used in this way, or if something is broken with it that i need to get fixed so that i can enjoy this lesson.
You can also actually adjust the park brakes shoes.. You may or may not know that v35 run a park brake setup where it has like drum brake setup which is in the inside o the rear rotors.. If u take your back wheels off u will see on the around the center of your rear rotor that there is a rubber grommets or plug.. Remove it then turn the rotor with park brake off.. Whilst turning get a torch and peep theru that hole u will see a sprocket looking mechanism.. Turning it will tighten or loosen your park brakes.. From memory it's located towards top of the rotor.. General rule is to tighten it to point where it locks up ad u can't turn the rotor and back off about 3 turns..
https://www.sau.com.au/forums/topic/389869-e-brake-issue/
You CAN'T drift a car with an E-Brake. The whole concept of drifting is that you need to hold the brake button in on a conventional handbrake so it doesn't lock in, so you can pull it up and down at will. In order to engage and disengage a foot brake requires considerable effort and time that makes it impossible to drift.
But I agree that the foot brake setup on the V35 leaves a LOT to be desired. I got sick of it not working effectively so a little while back I pulled off the rear wheels and tightened the adjusting screw to maximum possible (any tighter and the rear wheels would no longer turn) .... the park brake was effective for about 2 weeks, then it went back to how it was before. But it still didn't work effectively enough to completely lock the rears in order to drift - even if it were possible with a foot brake.
https://www.sau.com.au/forums/topic/389869-e-brake-issue/#findComment-6209993
Thanks for that NIght, thats exactly what i was looking for so im going to have to use the power of the car to initaite drift for this thing. I prob wont be able to do any 180's or anything like that the lesson is like a beginers thing to teach the basics of it all so i dont know much about drifting but i want to learn and im headded in the right direction. i will give up ont he E-brake now that i know that thanks again.
https://www.sau.com.au/forums/topic/389869-e-brake-issue/#findComment-6210008
The parking/emergency brake isn't really designed to lock the rear wheels, they are more there to prevent the car rolling on a hill or to slow the car down in an emergency (the latter not as much)
My suggestion is to completely forget about the e-brake entirely and focus on getting the car to slide via weight transfer
https://www.sau.com.au/forums/topic/389869-e-brake-issue/#findComment-6210039
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
