I have an adjustable speed sander/polisher, Ive used it as a polisher/buffer on cheap arse cars (buy cheap sell for profit) before and it worked ok on them with some harsh cutting compound.
But if I get decent lake country pads, clay bar and decent polish can I use the same machine?
It's a 6" ryobi from memory.
Will it do as good a job as a random orbital polisher or should I not waste the money on decent pads etc...?
https://www.sau.com.au/forums/topic/390104-sanderpolisher-vs-random-orbital/
Yes it will work ok.......but with a sander vs a Random Orbital there is a lot less margin for error. More chance of heating the paint up too much and burning etc.
If you have a fair idea of what you are doing then you should be ok, but it isnt ideal.
You can get a decent Bosch random orbital polisher for $150.
http://www.skylinesa...isher-feedback/ See post #12 :) the kits have pads and polish everything you need!
A RO like the concours 900 is ALOT easier to get swirl and hologram free finish with a sander/rotary machine its difficult for a professional let alone a hobbyist (not trying to put you down)
Edited by immacreflections
thanks for the replies guys, much appreciated...
now to to tell the partner I'll be spending just a bit more, if anyone has suggestions on how to do this without incurring problems Im all ears
Instead of "honey I need to spend a bit more" you say "honey I placed an order and fogot about the gravitaional pull of the earth when pricing up so I had to spend a bit more, but the orders already placed" :)
hmmm, not bad..
I used the 'honey it'll make your car look awesome', it did work, but I think I'll need weave the gravitational pull line into the conversation in regards to increasing costs... thumbsup.gif
For an enthusiast, go the RO. It's hard to damage your paint, it will take a bit longer then rotary polisher but still many times faster than elbow grease.
a straight rotary gets quick results.. right down to the undercoat if you're not careful. not worth the risk for casual use - if you polish cars every day they're a must but you HAVE to know how to use them correctly or you will do damage.
[quote name='75coupe' timestamp='1328232710' post='621665
Sweetie, Ive been trying to clean up the sink. Now there's a stain over there near the drain. See that? Now I'll be back from Bunnings in a jiffy and it'll be all gone by the time I attack it! Cya soon :)
nah Ive got it sussed she's now asking me have you got that polishing stuff yet? my car really needs it...
done... no drain stain or gravitational pull required.. damn I think I know how to operate the machine that is women, well getting there atleast!
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
