It's on like Donkey Kong!
On Sunday the 26th we will be holding a social based SAU cruise leaving from Perth and heading out for a decent run and stopping in York for Lunch. Now remember this is not a race (unless your name is Paul... :whistling:) but more of a fun cruise with a bunch of (reasonably) nice people from around and about SAUWA.
Departing: Midland Gate Shopping Centre. We will try and assemble at the undercover car park facing Great Eastern Hwy.
Time: Meet at 10:00am for a projected 10:30am departure.
Date: Sunday February 26
Bring: Money for lunch (or something packed to eat), plenty of fuel and your big boy pants as this is not a small map.
Whether you drive an early model Datsun, a Nazi Sled or an HKS tuned R35 GT-R all are welcome. Hope to see you there.
:cheers:
*Stay tuned for possible changes.
Dudley and I will be there with bells on!
so please contain your hillarity in the presence of the easily offended kthnx
Remind me closer to the date?
Cruising in an NA is going to be embarrassing. :(
Lol
Clearly you have no idea what Dale and myself will be captaining...
(You'll be more then fine in an NA mate, come along!)
... and I didn't make you buy Hitler's car.... :whistling:
If i recall correctly he drove in merc's. He funded and push VW as the everypersons car (well his everyperson)
Im NA so you will fit in no prob, hell i dont even have a skyline!
Lol
No Cossie?
You aryan sunamagun!
No Cossie?
I wouldn't put money on it mate, but anything is possible! Most likely roll in ze Celica!
No Cossie?
R32 golf?
been wanting to 'compare notes', i had to make the decision in purchase...
R32 golf?
i kept up (with out really trying) with a m's z4 the other week utill he started speeding. dont think he liked the fact i stuck onto his ass and woundnt go away.
Z4MC, or mates Z4?
traction comes in handy... my old 32GTST was useless until 80km/h +
and yes, the factory exhaust on the R32 gold sounds better :P
A M speed (or what ever its called, has the M badge on the back) one i have no mates..........................with a BMU!
Dale (Stinkyrooster) came for a ride on the weekend and loved the note out of the stock exhaust.
he mentioned.
people put M badges on everything these days, or there are m sport packs :P
A real Z4MC has the M3 engine etc.
I will bring a wading pool full of jelly and a couple of sequined mankinis in the back of the ute, so you two V2 pilots can hug it out, k?
Come to think of it, when did this cruise become all about reprezenting the losing sides of WW2?
isnt your car german?(not the 1200) :P
he mentioned.
*shruggs*
Saw the badge, it sounded nice and the guy looked like a tosser so i thought it was the full monty. once he started speeding it did take off quite fast. dont know.
mmm tub full of jelly
jlghdriog'erijyh'oeiAJRgh'J
*wipes drool off keybored*
sometime's the losers are winners...............................
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
