So recently I did a hard pull up a hill in third gear. Everything was normal but when I hit boost I noticed a whitish smoke coming from where the waste gate screamer pipe comes out the side of the car. When I got home I noticed that the top oil feed to the turbo was leaking a bit.Ever since then, after a hard run, and ai leave the car idling for a few minutes, white smoke starts to come out the exhaust which is fairly noticeable. I was thinking that the turbo seals have gone, allowing oil in to the exhaust causing the smoke, but since I've never had a leaky oil feed before could it be as simple as the oil leaking out of the feed being the problem? Or could it be that the previous owner had put too thicker oil into the car? (only had the car a few weeks)The turbo is a TD07 and is high mounted.
Any help is greatly appreciated. Cheers
https://www.sau.com.au/forums/topic/390741-leaky-td07/
Does sound like the turbo. But before you go spendong mony;
- Does the car have its.carbon canister/ pollution gear?
- Have you got the std PCV setup or running a catch can system?
- Have you checked to see if its using any oil?
- Is the engine built, standard...whats the history of the car?
https://www.sau.com.au/forums/topic/390741-leaky-td07/#findComment-6221894
I don't think it still has a carbon canister or even a cat, but then again I don't know if Fj20s came with carbon canisters?No it runs a catch can setup, which vents to atmosphere.It does seem to be using a bit of oil but I don't know if it's been doing it constantly or if it only just started recently with this smoke.As far as i know the engine is standard with aftermarket cams and a dirty great turbo strapped to the side which was fitted either just before it was imported by C-red or by the guy who bought it from them. I don't know exactly when it was imported as the receipts I have only go back as far as 2006 but I assume it was a bit before then.
https://www.sau.com.au/forums/topic/390741-leaky-td07/#findComment-6222110
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
