Hi all,
New to the site as of today and located in Perth. I have a 2004 model V35 GT 350 coupe and looking at fitting a towbar to the vehicle if it's possible ( preferrebly 2 piece ). Has anyone done this before or have some information that may assist me?
I have spied another post which talks of wiring a socket up for the lights o/p located at the rear of the vehicle to support the lights of a trailor, but not a lot of other details listed.
http://www.skylinesaustralia.com/forums/topic/236806-v-series-towbar-wiring/page__p__4146131__hl__v35+towbar__fromsearch__1#entry4146131
Cheers
https://www.sau.com.au/forums/topic/391237-towbar-for-v35-coupe/
These cars have an alloy rear subframe that was welded by Stevie Wonder.
What are you looking to tow with it?- a little box trailer with occasional garden stuff, or a very SMALL boat, you might get away with it. Otherwise you'll just crack the subframe and be up for $.
If its auto, you then have to look at a cooler. You are better off getting a old ute/fourby to tow and leave the 350 for cruising!
Thanks guys for your replies!
My car is a 2004 Semi-Auto V35 coupe. I want to buy a new jet-ski and really that's all i want to tow with my car. I really dont want a tow bar permanently visible on my car, so i did a bit of looking and there is a company in the states that make a kit for the Infinity G35 which is the kit that will fit my car.
(see link below). Its a two piece kit which means it will still look good when not towing as you can remove most of what is visible on the tow kit for normal driving, cruising etc. The only problem i have now is that etrailer.com WILL NOT send outside of the US and some other related states.
I wish i knew someone in the states that i could have it sent to and then have those people send it on to me. do you guys know of anyone that might be able to assist?
I heard back from Curt Mfg ( the people that make the tow attachment earlier posted. They wont sell direct to me as they are wholesale, but they did suggest to check out one of their retailers who MAY sell to me. I will send a blanket email to the retailers and let you know what i find out.
My link
A point to note also is these Curt hitches designed for V35 coupes are only good for towing about 600 odd Kgs i think (light trailers / jetskis etc)
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
