Gtr Injectors Upgrade Kit With Fuel Rail, Fuel Reg, Resistor Pack, Connectors And Adaptors $600 Sa
I have a GTR Injector upgrade kit with everything needed to get going for an rb25det, probably also fit rb20dets quite easily as well.
Comes with:
6x GTR 440cc Injectors with alloy adaptors for rb25det fuel rail
Resistor Pack
Alloy Fuel Rail with spacers
MagnaFlow Fuel regulator with bracket, speedflow fittings and hoses.
Loom connectors and wires for resistor pack and injectors.
This is everything you need to get GTR injectors on your rb25det, all you will need is to wire in the loom and get a tune! No stuffing around, 1 purchase and 1 set of shipping with everything you need in working order. Will support up to 270kw with the injectors alone, above 300kw by adjusting the fuel regulator.
Have removed these to install 740cc injectors, they are in perfect working order and were pulled off the car tonight.
$600 posted to your door anywhere in Australia.
Contact me via PM or call me on 0423 277 771
What it looks like installed on your car:
28708729.png[
Comes with the bracket, speedflow fittings and the hoses.
Edited by Rolls
  • 2 months later...
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
