  • Replies 190
If you have a ignition barrel pm me
pm sent,
do u have aftemarket turbo to cat exhaust?
yes but i need it for another car,
would you sell the gtr end caps alone? and how much for the fuel pump and o2 sensor.
end caps off the spoiler went with the spoiler, if your talking b-pillar trmis they are for sale.
fuel pump i need so not for sale, nor is the o2 sensor.
cheers,
Intrested in all 4 coilovers and intercooler info needed brands size costs condition etc
coilovers not for sale, stock cooler setup sold pending pickup
Hey mate, willing to separate the head ?
hey im keeping motor for another car
hey mate
do you have the plactic part that goes around the gear shift etc? just that one plastic piece?
i have a shifter surround yes but from memory it isn't perfect, may require coat of paint
i would have to check and get back to you
SOLD:
Air Duct Airbox to LHS Guard
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
A Pillar Trim
Driver Electric Window Switch
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
AC Compressor & Bracket
S3 Xenons
Rear Seats
Front Lower Control Arms
Boot Trims, Plastics, & Carpet
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
GTR Wing (boot lid still available)
Sunvisor Clips
Rear Hubs
BOV's & Return
Intercooler & Piping
i know your thread say minus the exhuast, but does that include only cat back or did the car have a front pipe at all on it? if so what type?
PM cheers
Daz
hey daz, i have stock front pipes lying around that i could sell but i'm using the full afternarket exhaust that was on the car
chris.
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
A Pillar Trim
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
S3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
Rear Mud Flaps
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
