Ok so i need to move in a few weeks and no longer need any of these parts as they have all been upgraded.. Can get more specific photos on request.
All items Located in penrith area NSW.. All prices are listed as ONO, worst i can say is no but nothing stupid please.
PM Me or Txt 0412589924
r34 GTT brake master+ booster $100+ post
perfect working order removed for a 33 gtr setup.
HKS split dump pipe +r34gtt oxy sensor to suit 3037/3076 or any GT 30 based turbo with a 5 bolt rear housing (I have a .86 int gate rear housing to suit for extra if interested)
It is used for approx 2000kms but removed to go ext gate setup. $200
RB26 clear timing cover painted 34 GTR red.. Was going to go with rb 26 covers but CBF anymore. $50 + postage
R34 GTT Half shafts+ Driveshafts. Suits any nissan with a 5 bolt half shaft and half shafts suit r34 gtt standard diffs.
Removed from my car for GTR shafts and a 2 way $100+postage which is half of what you would pay from a wreckers and these are ALOT better looked after
has a little bit of oil spilt on them but boots are great and perfect working order.
R34 standard flywheel $50
its flat with no heat spots etc removed to go a lightened flywheel
SARD universal battery relocation kit $350.. was going to use it on my car and run a GTR type catch can but dont need to anymore.
BRAND NEW only opened for pics, still has all the protective covers and bubble wrap etc
if you wanna see what it looks like properly look here: http://www.rhdjapan....minal-kit-21791
R34 GTT impul front bar $50 PICKUP ONLY bought from carmate to use as a Texi/track bar, it has cracks from hitting cones and shit but still mounts straight etc
would need a repair and paint to fit to a street car.
S15 Vertex side skits. $150 ono
FPR Has some scratches but is quite solid and mounts straight
THIS IS A SCRATCH NOT A CRACK
now for the random junk, throw me an offer.
R34 LED tail lights. East bear copies that came on the car but the red lenses have faded so you can either tint/nightshade them or put your existing lenses on these to get a cool LED style. It was my original intention to do just this but 2 jobs means no time for car crap like this. $40?? this is the only photo i can find on my PC
R34 GT standard ECU $20 good for someone with a blown board or if you just want the housing to put a Link G4 board in etc.
R34 standard GT injectors $20 good for a highflow otherwise ill just chuck em
https://www.sau.com.au/forums/topic/393330-aggromans-garage-sale/
dump sold pending pickup and payment.
Master+booster now $80
Timing Cover & flywheel $30 each
Sard Battery Relocation kit $300 (over 100 off what you would pay landed)
  • 3 weeks later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
