Ok here goes... I have had my apexi rsm (blue screen model) in my car for some time now. All works fine except the speed/quarter mile things... Anything to do with the speed reading does not work just simply it sits on 0. It has been wired up correctly with the instructions and the 180 km cut out works. How do i get the speed readings to work? Is there some tuning or settings that you have to play around with? It has only been installed not tuned to my car...
Any help appreciated...
https://www.sau.com.au/forums/topic/39336-apexi-rsm/
go to top menu, choose 3rd option (ETC), choose "car select" and make sure cyclinders is on 6, assuming its a v6, then set speed pulse to 2p (standard nissan) and thats it, it should be reading your speed signal, if you get no signal at all the wriring to your ECU is either wrong or damaged. if you have the speed pulse value on the rsm set wrong your speed will be doubled or in half as last temptation said, when youre doing 60 it will show 30km/h instead.
https://www.sau.com.au/forums/topic/39336-apexi-rsm/#findComment-800252
