overfueling causing a rich misfire due to air leak, dodgy afm, bad spark (coils or spark plugs).
That or it is leaning out due to fuel pump.
Smoke test the intake to rule out air leaks, replace the coil packs as good maintenance on a 20 year old car, new plugs with 0.6mm gap to confirm it isn't a spark issue. Change the fuel pump as good maintenance on an unknown 20 year old car.
  • Replies 50
Does the car run like absolute shit at all revs? If it is out by 2 teeth it would be terrible to drive!
I hope that is what is the problem, I just think if that was the case that whoever did the belt would have noticed straight away.
i bought the car like that, and the previous owner just changed it in the service, problem is whoever done it didnt know what they were doing as they were a genral mechanic, not a nissan mechanic specifically...it has to be that. its getting put on the dyno tomorrow, air/fuel ratios and boost are being checked and they will find out whats going on
Must have been a pretty shit mechanic if they can't line the white mark up lol. Nothing nissan specific about doing a timing belt.
Good call with taking it to a workshop, be easier than trying to guess what is wrong with it.
Edited by Rolls
yeah well these guys do skylines day in day out so they know whats going on, and he said garunteed they will find the cause and the computer can be read by them obviously so enough stuffing around with it ill get it looked at properly haha
Took it to Toshi today and he figured it out....
He said the way the stock fuel pump works, it gets a lower voltage when at idle and low revs and then the full 12v at high revs.
The Walbro apparently didn't like this so he wired in another ground so that it gets full power all the time.
Problem seems to be gone....lets hope it stays that way.
^^ good job mate. my problem is fixed too. coil pack #6 was missfiring. and the ecu wasnt grounding properly apparently. got a blitz dump pipe fitted aswell while it was there. made 145rwkw in 3rd. not bad for a stockie
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
